- 2:42 AM
- Dec 29, 2015
- Ontario, Canada
That’s exactly what I did.So you zero the angle finder from tooth to tooth, and then get the angle from tooth to raker? I think
Is it bad if the chips are real long, talking like over an inch or a few centimeters up your way .Quick video of a few test cuts. The wood is dry sticky spruce. I need some fresh poplar or something similar.
Here’s what the chips look like. View attachment 198692
If the wood is very wet, noodles typically are longer. Dry wood yields very short chip.Is it bad if the chips are real long, talking like over an inch or a few centimeters up your way .
I understand that.Every type of wood is different and every saw and chain is different so I can’t really say for sure
Never heard that, but I guess it would allow the tooth to rock more?Someone mentioned a while ago if the rakers were to tall, the cutter takes a thinner chunk when cutting, thus a longer strip of wood.
I had a chain like that. I took 2 swipes off each raker and chips got back to normal.
That makes sense too(not talking noodles, although some look that way). Since most cants are slightly wet softwood I would expect longer chips.If the wood is very wet, noodles typically are longer. Dry wood yields very short chip.
I have zero racing credentials, but I would be ecstatic to see those chips from one of my chains.I understand that.
I was just thinking as far as keeping things moving under the clutch cover.
This was a chain I did up for a 346, the first picture is in very hard seasoned cherry.
Second is in a pine log with the bark still in place but it was cut down well over a yr ago.
Thoughts/advice appreciated guys.
View attachment 198735 View attachment 198736
Thanks.I have zero racing credentials, but I would be ecstatic to see those chips from one of my chains.
That was on a little 346, it was moving them fine from what I could tell on the softwood.Long chips also indicate good chip clearance.
At least that is what I observed.
Thinning the cutter plate reduces resistance of the cutter as it severs the fibers and the generated chip flows underneath it - that is how I see it anyways.. . . I see the rear of the cutter is cut at an angle. And I see the inside of the cutter is ground out. Is that chip clearance? I assume along with the gullet and dog bone.
DamnUpdate, the saw and the fixture posted above was stolen from my garage not long after I posted it.
Any ideas who it was?066.......gone.
