concretegrazer
On what saw?
No..Did you tunnel the cutters before you tried that?
May have similar effect as tunneling. But only need one?
So my grinder isn't a piece of shìt?I just use the force..
The backs of the tie straps are lying bastards....
Stoning first might correct some of thatFactory produced chain is flawed..
But yer grinder could still be a piece of *s-word...
Lol
Done that..Stoning first might correct some of that
Been my experience too. My Force Foo isn't strong enough yet to eyeball them without using the arm stopsDone that..
Still can be *frenched up..
It’s where they index.. they all close, but not perfect for sure.
I can see it once it’s there, usually have to force it down a bump.Been my experience too. My Force Foo isn't strong enough yet to eyeball them without using the arm stops
I think you should have your "..." privileges removed... Lol.There is a trick...
I used the force a lot with the grinders I had. With Shaun’s bearing kit it was better hit indexing off the back the first grind or two still produced top and side beaks.
It seems the chassis heights are not very consistent.
Brake flag will guide you right to the next cut lol.Missed the up cut lol
Need to get the chip out a little better, but it’s cuttin nice.
Not at all. It drove me crazy. On a swing arm it was easier to hit the corner every time with chain being so inconsistent. It had a lot more flex with barely any pressure.
