Buy Used Saws CCC Ebay Store
Let's build me a red head 670!
Discussion in 'Chainsaws' started by Johnmn, Oct 10, 2018.
  1. Johnmn
    Johnmn Pinnacle OPE Member
    Feb 18, 2016
    1,784
    5,682
    340
    Minnesota
    So the 625/630/670 has got to be my favorite series of saws. They are simple, rugged and really keep up pretty damn good with the new stuff!
    The 625 is an open port 60cc saw.
    The 630 is a closed port 60cc saw that had ks and mahle cylinders. I have timed both and both have been very close.
    The 670 is the big daddy closed port 67cc both of mine are mahle but I believe Gilardoni made them as well.
    I currently have the saw tore down soaking in parts cleaner. This will also be real time and I'm gonna need to order some parts so it will be slow!
    Here is the cylinder I'm working with
    Czed, Fishnuts2, CJ Brown and 7 others like this.
  2. Johnmn
    Feb 18, 2016
    1,784
    5,682
    340
    Minnesota
    Still cleaning.....
  3. smokey7
    smokey7 Pinnacle OPE Member
    Feb 3, 2016
    1,184
    2,688
    275
    Detroit
    My favorite saw to build too. I have a few from 625 to 670 and blends of huskys too. If you need some stuff i may be able to share/spare s couple things. Ive gotten things payed forward to me from here and should probably do the same.
    bark, CJ Brown, XP_Slinger and 3 others like this.
  4. Johnmn
    Feb 18, 2016
    1,784
    5,682
    340
    Minnesota
    Thanks! I think I'm going to build this extra spicy for maybe a just for fun/GTG saw. But for now, bearings,seals, o rings, gaskets, impulse, fuel line and filter, intake boot, carb kit, meteor piston ect.
    I'm also thinking about a 266 p&c in my 630 just because it's a direct swap
  5. smokey7
    Feb 3, 2016
    1,184
    2,688
    275
    Detroit
    I have one with a 266 topend and i cant tell the difference with it and a 670 topend. I too feel like the 266 268cp 630 and 670 all run better then the 272. Or atleast sportier and more free.
    Mkinslow and Johnmn like this.
  6. Johnmn
    Feb 18, 2016
    1,784
    5,682
    340
    Minnesota
    Got more parts cleaned up last night! Hopefully more cleaned up tonight as well!
    redpete79, CJ Brown and Mkinslow like this.
  7. Johnmn
    Feb 18, 2016
    1,784
    5,682
    340
    Minnesota
    If I could post videos I'd post one on how well they run! I'm shooting to disappoint a 372 or 2! I know it can be done!
    Basher, smokey7 and Mkinslow like this.
  8. Johnmn
    Feb 18, 2016
    1,784
    5,682
    340
    Minnesota
    WKEND LUMBERJAK and Mkinslow like this.
  9. 5000+
    5000+ Super OPE Member
    Jan 19, 2016
    149
    348
    128
    pa
    Loaded with a 24" or longerbar burried the 272 will pull ahead.
    cus_deluxe, huskyboy and Mkinslow like this.
  10. Johnmn
    Feb 18, 2016
    1,784
    5,682
    340
    Minnesota
    Parts are in route!
    cus_deluxe and Mkinslow like this.
  11. old guy
    old guy Love me some Husqvarna
    Jan 21, 2016
    626
    2,018
    255
    Becker Minnesota
    Hey John, I can hear one of my 372s smirking out in the shop, I guess it's on.
  12. Johnmn
    Feb 18, 2016
    1,784
    5,682
    340
    Minnesota
    New bearings showed up today!
    I enjoy using @Mattyo tool for this!
    Quick and easy
    Heat up the case halfs in the toaster oven
    redpete79, Mkinslow and Dub11 like this.
  13. Dub11
    Dub11 Some body poisoned the watering hole!
    26,680
    99,675
    649
    Mkinslow likes this.
  14. Johnmn
    Feb 18, 2016
    1,784
    5,682
    340
    Minnesota
    Crank slides right into hot case
    A little 518 and the gasket
    Boom! Complete! I heat my cases to 325 for 10 minutes and every goes together slick as snot.
  15. Johnmn
    Feb 18, 2016
    1,784
    5,682
    340
    Minnesota
    On the older ones I slide them on the crank first and then they sit flush on the inside of the case. On the newer ones I install the bearing on the case first because they have a stop.
    huskyboy, Mkinslow and Dub11 like this.
  16. Johnmn
    Feb 18, 2016
    1,784
    5,682
    340
    Minnesota
    New o-ring on the seal retainer.
    I like to put some oil on the bearings
    Install seal in bearing retainer
    Then install retainer
    redpete79, Dub11, Mkinslow and 2 others like this.
  17. Johnmn
    Feb 18, 2016
    1,784
    5,682
    340
    Minnesota
    New bellows,kill switch and some heat tape oh and tank installed.
  18. Johnmn
    Feb 18, 2016
    1,784
    5,682
    340
    Minnesota
  19. Johnmn
    Feb 18, 2016
    1,784
    5,682
    340
    Minnesota
    This is where I need a little help timed the ports without base gasket.
    Ex. 107
    Trans. 123.5
    Intake 71.5
    Now I am thinking about leaving the transfers and taking the exhaust up to 103 and maybe intake to 78? Any thoughts appreciated!
  20. srcarr52
    srcarr52 We can't stop here, th1s is bat country!
    Jan 12, 2016
    2,023
    12,264
    445
    Iowa City
    No need to go larger duration on the intake than on the exhaust. It's only going to reduce your crankcase compression.
Loading...
Share This Page
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
