- 4:59 AM
- Dec 30, 2015
- Georgia
For any Command owners out there with an aging ASAM, DSAM, or DSAI ignition system Kohler has stepped up to the plate and is offering conversion kits to convert over to the MDI system for a very reasonable price. Here is what you need to do in order to convert an old CH with the ASAM to MDI. The process will be very similar for the CV engines as well as the ones equipped with the DSAM ignition.
Engine is on an Exmark Lazer Z but the process is more or less the same for all of them. Start by draining the oil, locate the oil fill for the engine.
On this model, it is the yellow cap on top of the valve cover.
Remove the cap so the engine can vent.
