Kerosene heater?
Flint Mitch
3:58 PM
Michigan
Not really an OPE thing....
I just scrounged a nice looking kerosene heater. I decided to put a new wick in before filing the tank, everything went back together fine I think. It runs but smokes like crazy. What did I do? It was completely empty and I filled it to half with brand new kerosene also.
Cracker Boy
Fl cracker
3:58 PM
Florida
Is the burner cylinder clogged? You have oem wick and not aftermarket? Your not running grade 2 red kerosene are you?
Flint Mitch
3:58 PM
Michigan
It's K1, i believe the wick is aftermarket since I bought it at home depot. Not sure on the burn cylinder? I'll have to pull it back apart tomorrow morning
Cracker Boy
Fl cracker
3:58 PM
Florida
Somtimes the wicks dont fit right and are not a blend of. Fiberglass and cotton mifht need oem and check and clean that burnpot
Flint Mitch
3:58 PM
Michigan
Will do. It was a fiberglass blend but I'll try oem and see
Cracker Boy
Fl cracker
3:58 PM
Florida
That and burn pot cleaning make sure it aint bent too
Flint Mitch
3:58 PM
Michigan
dont you have to let them soak before lighting the heater? i have a couple in for repair and thought i have heard this before
I gave it 2 hours before lighting. Instructions I found online said 1 hour
2:58 PM
Only time mine smokes is when I leave the door open and the little paddle pushed down for lighting. So maybe you have some extra air getting in there too?
