paragonbuilder
- 3:37 PM
- Jan 2, 2016
- Norwich, CT
So I have this Wright Stander I'm going to buy from my buddy with a Kawasaki motor on it. I was mowing and smelled oil so I pulled it in the shop. 100 psi on one cylinder, 50 psi on the other. So I figured valves, popped the motor off and put it on the bench.
Intake valve is shot on the right
The entire motor is covered in grime...
So it's obviously not being cooled properly.
After I pulled the heads I turned the motor over to check the cylinders and they look great but I heard something making noise in the crank case. [emoji16][emoji379]
Pulled the crankcase apart and this is on the bottom.
So now I'm at a full rebuild... Then I see this
one tooth missing.
Do I need a crank? Or will this be ok?
