Best Buy Co, Inc. Buy Used Saws CCC Ebay Store HLSupply Daily Deals
Just picked up an 084
Discussion in 'Chainsaws' started by Adamski, Jan 9, 2018.
  1. Adamski
    Adamski Plebus Splederns
    May 3, 2017
    792
    1,742
    208
    Essex, UK
    So I won a hidden auction (farming implements category) on flea-bay for this 084 that was in bits.
    £122 all in...
    Been talking to the guy/seller before buying it and he had pulled it to bits to replace the PTO case half that had cracked.
    Piston, rings, cylinder, crank yadda yadda are all from the working saw, which was working apart from the crack in the case.
    I am going to delve through the IPL but from a brief look all bits (main bits at least) seem to be there.
    So what should I look out for, any hidden gremlins or things to look out for other that the usual seals, rubbers etc? gonna mod the muffler, put new SKF's in and look at what can be improved in the cylinder without going over board.
    I will take pictures of the parts once I have given them a thorough cleaning.
    Yay 084!! :pesas::risas3:
  2. traffic903
    traffic903 Super OPE Member
    Aug 28, 2017
    315
    1,219
    193
    Australia
    Yay indeed!
    Adamski likes this.
  3. backhoelover
    backhoelover SERVICE MANUAL MASTER
    Feb 10, 2016
    1,050
    1,866
    228
    lincolnton nc
    @ray benson can get you a service manuals if you need one. Think that manual is too big to send via pm
    Adamski likes this.
  4. cus_deluxe
    cus_deluxe ONE OF THE WORST!!
    Jan 3, 2016
    1,852
    6,097
    363
    Michigan
    Careful with that muffler. Seems like thats one piece thats VERY hard to replace.
  5. Armbru84
    Armbru84 Pinnacle OPE Member
    Jul 14, 2016
    784
    3,125
    240
    Michigan
    Ditto on the muffler. A few buffers are NLA but the ones off 088’s work. Love my 084.
  6. ray benson
    ray benson Forum Research Librarian
    May 4, 2016
    1,699
    6,724
    330
    nw indiana
    Check your inbox for the ipl, owners manual, service manual and a couple technical bulletins.
    MattG, Lootbug, RIDE-RED 350r and 5 others like this.
  7. Adamski
    May 3, 2017
    792
    1,742
    208
    Essex, UK
    Cheers bud. I will do some night time reading..
    RIDE-RED 350r and XP_Slinger like this.
  8. Adamski
    May 3, 2017
    792
    1,742
    208
    Essex, UK
    MattG, Lootbug, RIDE-RED 350r and 2 others like this.
  9. Adamski
    May 3, 2017
    792
    1,742
    208
    Essex, UK
    Nice clean cylinder.. it’s hoouge..
  10. Beer Gut
    Beer Gut A Fine Pilsner
    Dec 20, 2017
    229
    691
    133
    Northeastern Wisconsin
    Nice
    Adamski likes this.
  11. RIDE-RED 350r
    RIDE-RED 350r ONE OF THE GREATEST!
    Feb 8, 2016
    2,836
    10,232
    368
    Blossvale NY
    Congrats, nice score! That's a big ol' hawg of a Creamsicle isn't it!
    Adamski likes this.
  12. cus_deluxe
    Jan 3, 2016
    1,852
    6,097
    363
    Michigan
  13. Al Smith
    Al Smith Pinnacle OPE Member
    Jan 14, 2016
    2,104
    4,912
    260
    Got one in the shed myself .Doesn't see much use .One reason they seldom wear out .
    Adamski likes this.
  14. Adamski
    May 3, 2017
    792
    1,742
    208
    Essex, UK
    I have been cross comparing the IPL's of the 084 and 088 to figure out what I have as a few parts seem to be causing me a headache.
    So can a 088 sprocket, clutch and oiler gear be used with an 084 oiler or even on an 084 crank?
    Can a 088 case be used with an 084 crank?
    It seems I have a very clean set of 088 case halves and a not so clean set of 084 cases. I also have an 088 oiler, 088 sprocket and the likes. I do not have the 084 crank oiler gear that is driven off the clutch sprocket. I have the newer 088 hook set up..
    It seems I have a hotch potch of a few of the bits and I am wondering what will work and what won’t.
    Thanks guys!
  15. mdavlee
    mdavlee Hillbilly grinder
    12,048
    51,171
    496
    TN
    Cranks are different on the flywheel end if I remember right. You'll have to use the crank and flywheel/coil combo that came with each. Then mufflers may not line up. Cylinder mounting is a little different as well spits not a simple swap
    Adamski likes this.
  16. Adamski
    May 3, 2017
    792
    1,742
    208
    Essex, UK
    Cheers bud,
    I'm pretty sure if I remember correctly the 084 cases I got were tatty but usable. Looks like there is a small section of the pto case half between the clutch and tank that has cracked off, nothing that a good repair couldn't fix, followed by a repaint.
    What about the oiler hose to bar output, are these interchangeable, the braided one on the 084 is wasted. Think there is a neat and clean one under the 088 cover if I remember.
    And then the chain brake handle is broken, an 088 (which I can get hold of) has a different part number to an 084, but I guess the mounts are the same?
    Just printed off two IPL's to figure out and cross reference everything into 084 and 088 piles. It looks like every part is there but whether they are 084 or 088 is hard to tell by eye, time to tick off the part numbers me thinks.
  17. mdavlee
    12,048
    51,171
    496
    TN
    The oiler hose probably interchanges. Alot of the oiler drive and clutch stuff does. Handle bars do as well.
    Adamski likes this.
  18. Adamski
    May 3, 2017
    792
    1,742
    208
    Essex, UK
    Quick question what does the round tang (21) connect to?
  19. mdavlee
    12,048
    51,171
    496
    TN
    I don't know right off. Somewhere to ground or attach to the switch. I'll try to look at mine if I have time later.
    Adamski likes this.
  20. Adamski
    May 3, 2017
    792
    1,742
    208
    Essex, UK
    Maybe the heated handle switch if their is one?
Loading...
Share This Page
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
