woodfarmer
- 6:46 PM
- Jan 20, 2018
- Bowmanville, On, Can
Use a razor blade to shave off the limiter bumps.View attachment 214882 View attachment 214884 how do I get my 2152 to look like my 2159?
I was hoping it could be done on the saw
+1It can be done on the saw.
Personally I would clean both saws real well and update the intake clamps while you are tinkering. Looks like both your saws still have the original plastic. Probably be fine but ehh it's cheap and easy preventive maintenance. Save you from a air leak burn down.
Steven
Yes but you can use a 385/390 intake clamp over the existing plastic clamp. Just have to do a little Dremel work. They're about $5. I go through a lot of them, ordered more this morning.View attachment 215036 Is this what the metal intake clamp looks like
That's why I leave the ramp.I snap all of both tag ends off of the plastic clamp and slip a 372 clamp under it. The 385/90 clamp over top is a little neater just make sure to leave a gap in the broken off plastic clamp so it can snug up.
I see what you did. I wish I had before I did my first.That's why I leave the ramp.
