You probably have eldarado/79-80 z28 rear calipers if it’s got built in parking brakes and gm based. I am a fan of manual breaks if you can get the correct set up! You could probably come close to retaining the Jeep master cylinder if you used the wilwood d52 twin piston calibers. 1/2 ton gm front calipers are usually happy with an 1-1/16 master with a vacuum booster, the “Corvette” master cylinder is a style that is usually used for disk/disk applications, they came in many different sizes. The other consideration is a Proportioning valve, some have a residual valve used on drum breaks to hold about 6psi line pressure. You will want an aftermarket proportioning valve like one from summit that has a dial to reduce rear brake so you can tune front/rear Bias. My 68 camaro is using 2005 corvette rotors and calipers front and back, it is perfectly balanced without a propositioning valve(even though I have a tunable one) and a 7/8 willwood master cylinder, this is manual, not power
