ken morgan
- 7:20 AM
- Jan 30, 2017
- yokosuka, Japan
I have a 2010 372xp that was a partial clone IE: flywheel side case, crank flyhweel coil are all oem and then the other side case, cylinder are AM. the carb on it is a walbro though I do not know enough to be able to tell specifically which type.
I am getting ready to put a good used OEM cylinder & piston onto the franken saw and would like to know if there is a better version of the carb for the 372 and if so what/how should I order for it? I do not want one for hot modded saw just one that delivers at stock or slightly higher (I will be gasket deleting and muff modding). Thanks for any advice or help in advance.
