Installing bearings that have the seals pre-installed
kfd518
5:02 AM
Central Texas
When installing bearings that have the seal installed already, how do you get the bearing on the shaft? Heat inner with soldering iron? Coil with oil then heat case and coil with oil? In order to keep from damaging the pre installed seals? Older stihls it seems used many of these.
Disciple of Monkey's
5:02 AM
They're not the interference fit like Pro saws are. the versions of this that I have worked on both Stihl and Husqvarna they just slid on the crank by hand, nothing special needed.
kfd518
5:02 AM
Central Texas
The 056s is what I’m getting ready to work on I have a spare seal but don’t want to have to use it Because I messed up the the pre installed one.
p61 western
Ol Mudflap
3:02 AM
GFY
I would freeze the crank, and then heat the bearing in a oven to say 150 degrees. That heat shouldn't hurt the seal, heck you could probably even go warmer if you want.
kfd518
5:02 AM
Central Texas
Alrighty, just hate to mess up a perfectly good seal if no necessary. Of course that old it might be hard anyways...... hadn’t thought of that
Fish
6:02 AM
Manton Ky.
Damn, I never had any trouble...
I just used old microfiche cards as a sleeve....
mdavlee
Hillbilly grinder
6:02 AM
TN
Press it on using the inner race if it’s going on the crank first. Even a socket with a small hammer will seat them. Warm the bearing up and leave the crank cold. I never liked freezing anything since condensation can happen rather quickly and cause more aggravation
1990Husky262
6:02 AM
Massacusetts
i use one of the old big soldering irons and ground the tip so bearing can sit right on it and heat inner race, heat till its hot enough when you spit on it it sizzles, Grab with pare of pliers and slide on crank and give couple light taps with pliers to make sure all the way seated. Gotta work quick cause does not take long to cool off and will end up getting stuck half way, if at right temp bearing just slides right on
kfd518
5:02 AM
Central Texas
Just pop the seal off...
And this is done how, without tearing it up? Honestly don’t know how to do so I’m sure if it was in hand it would be more obvious but it’s still in transit.
Marshy
WFO Cutting
6:02 AM
Mexico NY
I just use a mechanic pic and gently get under the lip and it just pops out.
kfd518
5:02 AM
Central Texas
Not the same type of seal. This is a double lip seal with metal outer diameter ring same as any other crank seal on a non clamshell saw. It’s the bearing pictured on the right.
Marshy
WFO Cutting
6:02 AM
Mexico NY
Same except it wont be as easy. Using a 90 degree pic allows you to get under the lip and then pry it out.
6:02 AM
I never thought of using a sealed bearing but I see no reason why it wouldn't work in some applications .The procedure as per Stihl is to freeze the bearing and heat the bearing pocket and install the bearing there in .Then freeze the crankshaft and use a big soldering iron to expand the inner race .Why Stihl used a heat shrink fit I'll never know ,just Stihl being Stihl I guess .
Thinking out loud ,with some creativity this might be an option to the often discussed elusive,next to impossible to find Stihl 042-048 clutch side main bearing and seal .
mdavlee
Hillbilly grinder
6:02 AM
TN
Depending on depth a 385 bearing with made in seal might fit. It’s a 6203 with seal in between the races
kfd518
5:02 AM
Central Texas
That’s exactly how this bearing is made. The seal is between the races. The bearing did come in the mail Saturday though I just wasn’t aware it was sitting in the mail box.
Thanks everyone for the input many ways to tackle this thing now.
6:02 AM
On the subject rambling on as I do .Where I worked,a Ford engine plant we used precision CNC machining that could repeat operations measured within micron ranges .Periodically the machine spindles would need rebuilt most using sealed precision bearing ,very pricey I might add .The people who set them up would get new bearings,pull the seals and use an ultrasonic cleaner to remove all the grease .Then repack them,rotate them and blow all the new grease out with compressed air .The only grease that remained was what clung to the balls.Reinstall the bearing with the seals and rebuild the spindles . Sounds crazy but the was the way they did it .
kfd518
5:02 AM
Central Texas
Well it’s amazing what happens when you remember your Stihl case splitter is also designed to put them back together......
Bottom end back together with new bearings work on the rest at a later date
afleetcommand
6:02 AM
CNY
And the stihl puller ( and others) can turn the crank helping it through the seal....if they are warm & oil everywhere the crank will go right through in my experience.
