295 tramp
Hillbilly Saws
- 8:47 AM
- Dec 23, 2015
- Minnesota
IMOA you have the top end off clean up the saw.
don't worry about junk falling into the crank case. once you get the saw clean
blow the case out with air, fill the case with gas, spin the bearings, dump the gas, blow it out again.
spin the crank to make sure no grit in bearings, do twice if needed once clean pour some 2 cycle oil on bearings spin them around.
any excess oil in crankcase is going to clear out once you start the saw.
clean the base with brake cleaner and apply thin coat of 518 to both surfaces install, done
I never use Loctite on cylinder bolts
