blsnelling
Friend of the Riff Raff
- 9:32 AM
- Jan 8, 2016
- Franklin, OH
At least it's not a strato. Looks a lot like a 461/661. I suspect you'll get good gains from this saw.
....Du weißt aber, dass die Säge jetzt neu kalibriert gehört, am besten am Diagnosegerät?!
Steph, du kannst die MS 500i auch wie die MS 462 C-M kalibrieren. Aber wenn die Kalibrierung mit Diagnosegerät gemacht wird, werden evtl. aufgelaufene Fehler mit angezeigt. Generell ist es nach solchen Eingriffen besser egal ob 462 oder 500i die Kalibrierung mit Diagnosegerät vorzunehmen.
Those are pretty good numbers to start with without bass gasket. Very nice pics.
timings with base gasket (i will check the timings again without the gasket on thursday)
squish with gasket is around 0,75mm / 0.0295"
54mm bore
and back together for more stock testing tomorrow
We need ENGRISH TRANSLATION Please....
I’ll translate... “How are we gonna get this thing to out cut them dam hooskies?!”
That shouldn't be to hard.I’ll translate... “How are we gonna get this thing to out cut them dam hooskies?!”
Answer: Start by putting Humpty Dumpty back together??I’ll translate... “How are we gonna get this thing to out cut them dam hooskies?!”
Soo, it's 54 bore? 37mm stroke?? Did they up the bore from 52 making it closer to 87cc? Last I saw it was supposed to be an 80cc saw ; 52 bore 38 stroke.
54mm bore
