Inside the MS462C
StephK87
4:02 AM
Germany
I have a new info from a friend on the 500i, he was on a forestry fair in munich today (he also made the pic's of the filtration i'd posted before) and he talked to a Stihl technician at their stall,
he said Stihl recommends to push the primer pump on the 500i up to 8x times before every start of the saw, because you have build up pressure for the injection system, otherwise it can be difficult to start the saw. :clapclap:
9:02 PM
That sounds like alot of fapping
StephK87
4:02 AM
Germany
The enemy is here [emoji16] next week another 462 will show up [emoji123]
10:02 PM
I'm not familiar with a 462, but none of the M Tron saws officially have a "choke". Generally they just have "Start", "Run" and "Off".
There are times when High Idle would be nice.
Also, "Start" is for cold start, warm starts should be done in "Run".
T.Roller
10:02 PM
Southeast, TN
Cold start is the choke. It has a choke butterfly
Willard
9:02 PM
Manitoba
Ok delete my question guys.
Had a little brain fart there, just looked at my MS261 and it has the same icons on the cover as the 462 in the Swedish video
I do like the 261's integrated fast idle and choke, one click on the trigger after a cold choke and she's ready to go. If you got a hot start flood issue just hold WOT and do the throw start.
My 550XP have to manually set fast idle after cold choke and set everytime for a hot start after working it hard.
