- 12:45 AM
- Oct 18, 2016
- GFY
Thank you. I was just on their website, and was wondering what product it was. I bet it works great on carbs.
Strip off all non metal parts and the rest comes out beautiful shiny just like new metal, it may destroy carb check nozzles. I have used it mostly to clean old Tillotson HL carbs on vintage saws. This stuff also comes in 4 liter cans, about same as a gallon size.Thank you. I was just on their website, and was wondering what product it was. I bet it works great on carbs.
View attachment 113949 View attachment 113950 oops got the oil Flo name wrong lol. We only use it to wipe down are plate after a bug lands on it cause the plate on my press is running at 400 degrees.
I'm trying to find it here, but no luck yet. I won't give up though. Your right it will probably eat the check valves. It sure would be nice to soak some of the older sdc carbs though.Strip off all non metal parts and the rest comes out beautiful shiny just like new metal, it may destroy carb check nozzles. I have used it mostly to clean old Tillotson HL carbs on vintage saws. This stuff also comes in 4 liter cans, about same a a gallon size.
Yep this state is really choked off due to the epa. It gets to be a real pita. I will probably have to get some of that cleaner from Reno,Nevada.
I got it soaking now with vinegar and spray nine. I cpuldnt find the simple green you recomended.I'm going to have to give this a try. It sure sounds better than my white vinegar and simple green mix I have used.
That clutch looks strange for sure. You can find the right ones on ebay for a decent price. P41,p51,p61 and so on are all the same clutch.Grabbed a pretty darn good deal on a P52 today, first for me, oddly it has a two shoe clutch, did some of these come that way or do I need to keep my eyes peeled for a three shoe?View attachment 119781 View attachment 119782 View attachment 119783
I'll check the 41 series, I couldn't find any under the other model numbers....That clutch looks strange for sure. You can find the right ones on ebay for a decent price. P41,p51,p61 and so on are all the same clutch.
You can look at p42,52, and 62 as well. If not chainsawr might have one as well.I'll check the 41 series, I couldn't find any under the other model numbers....
There is one for a poulan pro 405 right now. That's just a newer p41, and it will work.I'll check the 41 series, I couldn't find any under the other model numbers....
Thanks, I couldn't find any under the other models.There is one for a poulan pro 405 right now. That's just a newer p41, and it will work.
That one is a good price as well.Thanks, I couldn't find any under the other models.
Yep, I made him an offer, still waiting on his reply....Oh, and thanks for the tip, I totally forgot about the 405.That one is a good price as well.
Hopefully he accepts your offer. Yep the 405,455,525, and the 655 all use the same clutch.Yep, I made him an offer, still waiting on his reply....Oh, and thanks for the tip, I totally forgot about the 405.
Yep, he did, I was quite sure that two shoe clutch was from a smaller model, the spline felt a little loose on it as well....Hopefully he accepts your offer. Yep the 405,455,525, and the 655 all use the same clutch.
