MS290man
Folks, I’ve got a weird one. MS250, looks like low hours b/c I have 135 psi compression and p/c look like new (as seen through intake and exhaust ports). Saw was run for unknown amount of time without air filter. Couldn’t have been long (I assume) given there is no visible damage to cylinder/piston. The weird thing is that it seems to hydro lock after 4+ pulls. At first I thought it flooded so bad that the case was full but if I pull it through slow it seems to free up after a half dozen cycles. I shut the fuel off completely to rule out flooding (closed both needles) but it still starts to lock up. Also tried a bit of straight 2 stroke oil directly into the cylinder (to rule out piston seizure); no difference. Could this be crank bearings going bad? The owner wants it fixed if it’s simple but he’s junking it if not. Just worried about putting hours into this saw if I have to rip it down to the crank. Thoughts? FYI - when I took it down I realized the starter cord had been repaired (way too short) and the flywheel nut was laying loose in the recoil housing.
