Yukon Stihl
- 4:36 AM
- Jan 11, 2016
- Great White North
i hope the red spice is cayenne pepper
Didn't want to go up on her eh?I'm 6'1", and back when a friend of mine wanted me to go out with this girl who was 6'3". I balked, looking back at it I was a jerk, she was pretty and nice, my loss!
weight, helps lighten the pocket book
around 2 lbs I think
I’ve told a few that they made an updated 1128 case with a stronger crank and more metal, also more Case capacity. They even added a poly flywheel to save some weight.So I have a question - maybe a stupid one.
What is gained by going with an 044/046 or 440/460 hybrid over just a 046 or 460 or 461? I am genuinely curious.
Yes. All oem Stihl PTO Bearings have been, at least for me. Seem to hold up fine.Are those plastic cages on the pto side? Just curious. Nice build Doc!
I usually Vac test all. It’s a bit of a waste of time in this one as it’s all new OEM, the seals were installed correctly with factory tools, and even the case halves has Dirko applied before the oem gasket was placed there.I’m curious of your order of assembly. Why do you install the muffler before completing a vac/press test?
101-102 ExI presume 101 is the Ex, care to share the rest of your #s?
I wouldn’t test it either, I only vac test saws if I have an issueI usually Vac test all. It’s a bit of a waste of time in this one as it’s all new OEM, the seals were installed correctly with factory tools, and even the case halves has Dirko applied before the oem gasket was placed there.
Plus, 044 design can leak at the crank spacer and make one chase their tail.
Not saying it’s optimal not to test, but I did all the building and all the work. I think I’ll be ok. If it acts like a leak, it will take me 15 min to check it out.
Tank is AM. I’ve located the correct decals. I know that sounds dumb, but I enjoy the factory look and it wasn’t much more expense or time. That is, until it starts to leak.Looks new
I vac test every saw I port if it’s all used, cause it’s a cat in the bag and it’s well worth the time investment.I wouldn’t test it either, I only vac test saws if I have an issue
Guys tend to send saws and overlook any problems. Some honestly think that the redo of the cylinder will fix the running issues-this is rarely the case.
I’ve yet to have an all new build leak. I only go oem on the case parts and bearings as the cost is nearly all labor. One looks at saving a whopping $30 using AM parts there. Would you build a house on a straw foundation?
