Buy Used Saws CCC Ebay Store
Hybrid Time
Discussion in 'Chainsaws' started by drf256, Dec 16, 2018.
Tags:
  1. Bryan Barrow
    Bryan Barrow Super OPE Member
    Apr 28, 2018
    164
    498
    103
    Plainfield, CT
    What kind of tachometer is that?
    Mkinslow, AlfA01 and RI Chevy like this.
  2. RI Chevy
    RI Chevy DollyKitaStihlvarna Runner
    May 7, 2016
    17,156
    39,569
    473
    Ocean State
  3. blacksmith
    blacksmith Super OPE Member
    Dec 14, 2017
    246
    884
    138
    central PA
    I am sorry I am not sure if I missed something but when the 12mm crank was put in the 10mm case was the back of the connecting rod groud down for clearance?
    I put a 12mm crank in a 10mm case but me and @Scotty Overkill made the relief in the case itself for the clearance. I thought about taking the excess off of the back of the connecting rod but I was worried about taking the temper out of the rod and causing a weak/failure point.
    I forget what thread it was in but Scotty posted about what I did destroying the eclip lip on the PTO side of the crank. This lead me to look for another 12mm crank to replace it. @Armbru84 alerted me to a good used OEM crankshaft /crankcase it was listed as a 12mm but once I received it it was actually a 10mm setup. We did make a repair to the eclip lip by preheating welding it up and cutting a new slot. So far it's holding up but I'd just like to have another crank on hand if a failure occurs.
    So I am still looking for a good used OEM 12mm crank. I have a good used OEM 10mm crankshaft for trade. If anyone is interested.
    AlfA01, MustangMike, RI Chevy and 6 others like this.
  4. blsnelling
    blsnelling Friend of the Riff Raff
    Jan 8, 2016
    970
    5,196
    387
    Franklin, OH
    Not an issue at all. We've been building them for years, as Jacob J pointed out.
    This 044 isn't destroyed, just modified. To each their own.
    BTW, the saw sounds great!
    Hinerman, Semotony, smokey7 and 11 others like this.
  5. Scotty Overkill
    Scotty Overkill Serial Tree Killer
    Jun 14, 2016
    450
    3,216
    240
    central PA
    Very nice, brother!
    smokey7, AlfA01, blacksmith and 4 others like this.
  6. MustangMike
    MustangMike Mastermind Approved!
    7,677
    22,329
    513
    Great job Al. Does the saw feel lighter with that filter setup? I hear they are.
  7. BonScott46
    BonScott46 Pinnacle OPE Member
    Jul 20, 2016
    444
    1,207
    208
    Sweden
    I don't think they are much lighter but the compactness of the setup is a plus IMO.
    MustangMike, Mkinslow and RI Chevy like this.
  8. Frank bierce
    Frank bierce ONE OF THE GREATEST!
    3,591
    12,266
    408
    Oregon
    I have to get my hands on a hybrid one of these days!! Not sure how I missed this thread before.
    smokey7, Basher, MustangMike and 4 others like this.
  9. drf256
    drf256 Dr. Richard Cranium (“RC” to Muh pals)
    6,719
    42,388
    543
    Used the JMS Tool (belt sander) to relieve the large rod end a drop. I went perpendicular to the crank to avoid any stress risers from forming. It doesn’t get hot, so I doubt that any temper issues occurred. I got .009 clearance on the rod end and more on the stock/untouched weights. I tied up the gaps with twine to minimize the metal fragments getting in the bearing.
    25350386-A894-4215-BCAE-E8FAFBF63B14.jpeg 0C1B38F3-E465-492D-B63D-324C5705707F.jpeg 57D8CFD3-8234-44C6-9311-ECAD541CE7E9.jpeg 7DCB6332-AEE8-46A3-A6CA-4EBA798B5338.jpeg 8C183306-93AD-4BA3-AA6A-650BF557F72B.jpeg
  10. drf256
    6,719
    42,388
    543
    The entire setup is pretty flimsy compared with the HD setup. Dan will be getting an HD setup to run with this saw. I personally wouldn’t use the stock setup for anything but a few cuts here and there. Any real tree work and I’d want the HD setup on there.
    treesmith, Semotony, Dub11 and 12 others like this.
  11. drf256
    6,719
    42,388
    543
    No, I did not. I honestly wanted to touch the least amount possible on this saw.
    I love the Ducati coils in general, but I’m not sure if this one has low speed timing retard like the others generally do.
    It bit me twice on startup. Contrary to what many think it’s not compression and CC’s that will bite ya, it’s the saw firing BTDC that will do it.
  12. RI Chevy
    May 7, 2016
    17,156
    39,569
    473
    Ocean State
    Did that Ducati coil come stock with that 044?
    Duane(Pa), Mkinslow and AlfA01 like this.
  13. AlfA01
    AlfA01 Powered by Olive Oil and FETA Cheese..
    Mar 8, 2018
    2,883
    17,853
    430
    Evia, Greece
    Yep that is the stock coil.
  14. drf256
    6,719
    42,388
    543
    +1
    Semotony, RI Chevy, Duane(Pa) and 2 others like this.
  15. BonScott46
    Jul 20, 2016
    444
    1,207
    208
    Sweden
    I put the timing back to stock on the Mofo 044 i have. Timing was advanced .020+ and when it would act up you could not even approach tdc without it firing and blowing the handle out of your hand. I have never felt another saw do anything remotely similar. Not sure what coil it has...
    smokey7, MustangMike, Woody and 4 others like this.
  16. usmcbuckwild
    usmcbuckwild Buck
    Dec 24, 2017
    2,518
    13,902
    425
    NW CT
    Damn! I need to start looking for parts; I want to build me a hybrid
    Dub11, smokey7, Duane(Pa) and 5 others like this.
  17. RI Chevy
    May 7, 2016
    17,156
    39,569
    473
    Ocean State
    Interesting on the Ducati coil on that stock 044. Good deal.
    AlfA01 likes this.
  18. Sty57
    Sty57 Mastermind Approved!
    Jan 6, 2016
    6,416
    40,331
    510
    Land of Cheese & Beer
    I really like mine a lot.
    Semotony, drf256, Duane(Pa) and 3 others like this.
  19. AlfA01
    Mar 8, 2018
    2,883
    17,853
    430
    Evia, Greece
    I've been looking since Al posted that pic. No clear evidence on which coil those saws came with that I can see.
    It's a 0000 part number so available across multiple platforms.
    I've seen the Ducati, the SEM Sweden, the US coil and the Japanese ones so far.
    I have all of the above on different saws.
    Duane(Pa), Basher, RI Chevy and 3 others like this.
  20. usmcbuckwild
    usmcbuckwild Buck
    Dec 24, 2017
    2,518
    13,902
    425
    NW CT
    I see that from everyone who has one. I’ll keep my eyes open for some parts
Loading...
Share This Page
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
