msmmce1
Active OPE Member
- 3:23 PM
- Jan 31, 2019
- Richmond va
My Huztl MS440 seems to be drenching the area around the oil pump with oil, soaking the clutch and running out from behind the clutch after running. The output tube seems to be seated however the face of the pump inlet doesn't seem to seat all the way down on the pick up tube. Appears to be coming from the drive gear area of the pump, is it normal for oil to leak there? It does oil the bar fine and when running without the bar I can see it pumping.
thanks!
thanks!
