Kyler Monares
- 1:16 AM
- Mar 3, 2017
- Gonzales, Ca
Hello all, Just received my 361 and 440 kits from huztl. i opened the box and it appears nothing has been damaged in shipping. going to open all the packages in a video. This will be my build thread. To start off here are all the OEM parts i ordered. Heres some Stihl P/N's for the 440
Seal Kit: 1128 007 1050
Intake Manifold: 1128 141 2203
Wrist pin: 1128 034 1501
Circlips: 9463 650 1200
PTO crank bearing: 9512 003 3061
Flywheel crank bearing: 9503 003 0354
also going to use an OEM 3/4 wrap handlebar
FYI: Stihl OEM Decomp valve: 1128 020 9400
Flywheel thread pitch is M8x1 and Clutch is M12x1 Left hand. Info if you would like to make a crankshaft installation tool.
Now that i have the crank i should be able to figure out the thread pitch for both sides so i can make an instalation tool. if anone has any extra advice i would love to hear it all. I also have a sevice manual and IPL for the 440. Should make the build go 10 times easier!
Thanks in advance,
Thanks in advance,
