mutti_wilson
- 1:35 PM
- Nov 2, 2016
- La Center, WA
My presence lever and trigger broke off while cutting and I got a key to replace them. While test fitting everything I felt like it wasn't going to work well if at all. The pieces just didn't seem to mesh at all. I threw the thing together springs and all and no matter what position I held the 2 levers I could not get them to mesh and work. I ended up shaving a bit off the presence lever and got them to at least fit together. I then noticed another issue. Either my handle is worn out or the part is bad because it's allowed to come quite far out of the handle. There is probably 3/16" of daylight between the back of the lever and the handle. Still takes the stars aligning to get the trigger to move and it's notchy at best. At this point I just took the presence lever off and am running it that way. Anyone else have this issue? Could it just be the parts I got?
Sent from my Pixel 2 using Tapatalk
