kfd518
- 10:37 PM
- May 13, 2018
- Central Texas
I’m having a problem with my 394 throttle. I was attempting to tune it and adjusting the high side it maxed out at around 11,900 slobbering rich. I realized that when squeezing the throttle it will normally only open to about 85-90% sometimes it opens fully to the throttle stop not often that I get the fluke of it opening all the way.
I believe it is a problem with the cable because if I push either end of the sheath towards the middle of the cable it will open full throttle every time I keep it pushed.
Am I correct in thinking this or is it more likely that the trigger mechanism or the clipped on adapter on the throttle shaft is worn?
When replacing the cable is it common practice to replace all 3 parts or does a cable replacement alone normally fix this issue? I would just like to have all necessary parts on hand to fix it the first time.
I have not noted any way to adjust the tension on the cable sheath like you can on say a bicycle brake cable. Please correct me if I’m wrong on that?
Fully closed
Trigger pressed all the way
Pushed all the way open by hand
Fully closed
