- 10:41 AM
- Jan 8, 2016
- Farmington, CT
Yea.... this works just fine.
I destroyed a 262xp case by missing the screw under the dog...or...not thinking those WERE case bolts lol
Never seize, couple drops of motor oil, just about anything along those lines makes it easier... Good tipNice video! If you put a little never-seize compound on the tip and on the threads of your puller it will create a lot less friction making it easier to turn the jack bolt. Handyman tip of the day
The whole "impact" thing has its place in applications like this. The rattle helps nearly as much as the pullNice video Mattyo. I use a impact to bump the jack bolt alil. Much easier than a wrench
I can take a q-tip size drop of anti seize and have it on everything in the shop!Nice video! If you put a little never-seize compound on the tip and on the threads of your puller it will create a lot less friction making it easier to turn the jack bolt. Handyman tip of the day
It must be scientifically formulated to do that! I use it almost everyday at work and I find it behind my ears, on my socks, on my money clip in my pocket. I mean seriously, how is that possible!?I can take a q-tip size drop of anti seize and have it on everything in the shop!
lolChit if you seen mine you would think I was workin in a broom closet.
