Husqvarna 362xp needs love, coming back to life. 1 LIVES!!!
decableguy2000
12:37 PM
WNC
Picked up a 1999 362xp today for cheap. Starts and runs. It suffered a trees wrath,
brake handle broke- have on hand
handle bar bent - have on hand
cylinder av damaged - have on hand
front av Bent - have on hand
Now the bad, missing clutch cover, small mount, some what rare
case is broke behind the clutch where the movement limit screw is
Muffler is dead and will have to cut it off to check piston
So should I convert to a 365/372 case? Have extra clutch covers on hand. New, used or after market
I'll get a picture up when I get home from work.
Adamski
Plebus Splederns
4:37 PM
Essex, UK
Change the case, change the bearings whilst at it. I don’t think there are any 362 am clutch covers. They are a slight different stud spacing as well as diameter. I thought about tig welding a 372 cover up and re drilling the holes to suit the 362 case. In the end I changed the case to a 372 used case and put new skf bearings whilst at it and stuck a 365 oem cylinder I had to hand. The 362xp cylinder can be made to run well though. An rev like a mad ass hornet.
decableguy2000
12:37 PM
WNC
Still undecided on what I'm going to do.
Piston looks good, but top fins are broke.
From what I can find OEM case and clutch cover are available but expensive.
Has a new oem starter cover, and new HD12b carb. I believe the saw had little use until it got crushed.
Mkinslow
11:37 AM
Tennessee
I've got a set of cases. Was saving for another 365 build but I'd part with them if itll help you out
Wood Doctor
Edwin
11:37 AM
Omaha, Nebraska
I just "made love" to a Stihl MS661 C M that got run over by a 12-ton skid loader. It took $500 in OEM parts (no after market available) to put it back into running condition. The owner insisted that I try to repair it. The handlebar was bent into a pretzel, the chain brake snapped off, the case showed stress cracks, pull cord housing ruined, tank housing destroyed, etc. etc. Sometimes I just cannot believe how much punishment that a saw's case can take and survive.
It was a whale of a gamble to spend that kind of dough on parts without knowing if the saw would run again. It's got 155 psi compression and it started and ran yesterday. I guess the Man upstairs was on our side. Frankly, I was almost in shock and in disbelief when it kicked over and fired right up. :rolleyes:
I can show Pics, but I do not want to hi-jack this thread.
RIDE-RED 350r
12:37 PM
Blossvale NY
Myself, I would try to keep it 362 just because there aren't many of them around. But if you're looking to build yourself a work saw I might get her going with whatever 365/372 parts I could scrounge up
decableguy2000
12:37 PM
WNC
New build thread coming. A lot of scubbing and a couple of beers, I'm ready to pressure and vacuum test one 362. A second one going to get a bath and stripped down. New bearing, gaskets etc. A third in the works that will be built on a Farmertec case with OEM guts. If I can remember to order all my small parts I'll have 5 or 6 milk crates empty.
12:37 PM
Xpw sleeper
Wolverine
dilligaf
12:37 PM
decableguy2000
12:37 PM
WNC
Here goes a beered up build from 3 no runners to maybe something nice. Started by cleaning the case I received in the mail. I had a set of OEM gaskets and seals, for the China case I bought.
decableguy2000
12:37 PM
WNC
Crank and Bearings from the broken case, low hour well maintained before it was attacked by a tree. Crank and bearing fresh out of the freezer, and case out of the oven. All the hardware cleaned up.
RIDE-RED 350r
12:37 PM
Blossvale NY
So you're keeping it a 362, cool!
I've never seen a 362 torn down, those lower transfers are interesting. Are the uppers quads or duals?? Kinda hard to see in the pics, but they look like dual??
