JMoney
- 2:48 PM
- May 16, 2017
- Kansas City, MO
Hi everyone, I found this place through Mastermind and TreeMonkey's Youtube channels, and this is my first post over here. I just picked up my first pro saw. It is an early (2002) Husqvarna 359 that has been well loved but is in pretty good shape. It is 100% stock.
I'm going to install a full wrap handlebar since I'm a southpaw, and the previous owner had purchased a metal intake clamp and new boot. I've never owned a saw with a bolt down jug, and I haven't needed to break open any of my clam-shell saws. I have been learning the hard way that it really pays to plan jobs on saws because the shipping will burn you otherwise, so I want to start thinking about everything I want to do while I have the jug off to replace the clamp. I don't really need more power, but I like to tinker anyways so I'm considering a few simple mods.
Carb - Its a HDA 199, I've seen TreeMonkey's video on them. Should I send it to him/do a kit, or just leave what ain't broke alone (it's running just fine now)? I will at least be removing or trimming the limiters.
Gasket delete - I know this is supposed to provide a lot of gains, but there is some question about reliability with various gasket makers? I've read how to measure the squish but I would have to buy some calipers. Could I make my own paperboard gasket to be thinner instead of using gasket maker? If I decide not to delete, can I re-use the original gasket?
Clean up the jug - I don't plan to do any port work myself, but I was wondering if I should consider sanding the exhaust ports, transfers and stuff. Only if there is noticeable casting defect? Or should I just polish it up. Can I do it by hand, or should I use a dremel? What grit? I am a bit nervous about taking a dremel to it, even just with sandpaper.
Muff Mod - currently running a stock non-EPA muffler, I will probably leave that alone in case I need to be somewhat quiet in the future, then order an arbor-tec muffler and modding. I don't cut in areas that are subject to scrutiny regarding spark arrestors, but we do have very high fire risk out here, so I would prefer to leave them intact. I can weld but not well, so I'm hesitant to try welding on such thin metal.
Anything else I should do? I just replaced the fuel line and filter last night, and will be placing helicoils in the mount of the bucking spike, then installing the large spike kit.
Whew, thanks for sticking with me, through all that,
Justin
Edit: sorry this probably should be in ask the experts, if a mod could move it please that would be great.
Justin
