jmester
Project that I am starting on. Got a toasted 350 that I am going to put a 346 cylinder on. Got the case cleaned up. The riser ground for the impulse passage. As the 346 cylinder pulls impulse from out side the cylinder bore. The 350 pulls pulse from inside the cylinder bore. Flattened the riser on both sides. The bottom of the riser that meets the case is the area that needs the most work. The screws over time pull the corners down and give you high and low spots across the sealing surface. Got the case sealing surface rough up with sandpaper to provide more bite for the sealer. More to come as I make progress.
