psuiewalsh
Basement Bodging
- 4:56 PM
- Dec 23, 2015
- Nottingham,pa
Do you then have to change the screw to a regular m5 instead of plastic treadtype?
I have used jb weld plastic bond on those screws that are stripped out in tank on my brothers saw. He's uses it quite a bit with no problems.Does anyone know the thread and pitch of the coarse screws that the AV's attach to the tank? I believe they are m5 but I am not sure of the pitch. I have a pulled one at the rear upper mount of the tank. I want to find an insert and try and fix it. Maybe not possible as it is near the tank and may cause a leak. Either it is possible or I will JB weld and set the screw in...
And which screw do you need after the insert is installed?I was 12% wrong the anti vibe mount insert is 50327001. It is the larger of the 2 they offer and requires a 7.1mm drill bit.
Right guys on my ‘new’ used 346xp top end what am I looking for across the piston. I measure around 41.74 minimum. It looks like the piston has been refinished. Probs a bit more than I would have done. On the plus side it has come with a new caber ring.
And a few of it all clean. The 340 starts and runs good. Sounds good with the muffler mod. I think I will shelve the cylinder and piston for a rainy day when it comes off.View attachment 97034View attachment 97035
The muff mod looks just right.
Hows that Zombie Survival guide?
Whats number 1 ?Thanks for the agreement on the muff mod. The guide is a laugh. Quite in depth really. At least I know a chainsaw is in the top 5 survival weapons...
Think it is a samurai sword? Apparently the start up procedure to a saw is too long winded for close combat...
