Best Buy Co, Inc. Buy Used Saws CCC Ebay Store HLSupply Daily Deals Lumber Liquidators
Husqvarna 340/351/346 new little snarly wanna be
Discussion in 'Chainsaws' started by Adamski, Nov 10, 2017.
  1. RI Chevy
    RI Chevy Stihl Runner
    May 7, 2016
    11,696
    24,321
    423
    Ocean State
    Very clean, nice little saw there.
  2. Lightning Performance
    Lightning Performance Knuckle dragger swinging member
    Jan 26, 2016
    2,057
    3,584
    255
    South East North East
    Are you still building saws?
    RI Chevy likes this.
  3. blsnelling
    blsnelling Friend of the Riff Raff
    Jan 8, 2016
    872
    4,697
    297
    Franklin, OH
    I haven't been taking regular saw work for more than 1 1/2 years. I've done a couple here and there, but very little.
  4. Adamski
    Adamski Plebus Splederns
    May 3, 2017
    771
    1,651
    208
    Essex, UK
    Off the top of yer heads does anyone know what the bearing number is for the 350's? I am looking through the SKF catalog and cant remember the standard bearing number, not the Husky part number... eurgh.
  5. RI Chevy
    May 7, 2016
    11,696
    24,321
    423
    Ocean State
  6. Tor R
    Tor R Regular member
    Jan 8, 2016
    2,921
    13,100
    406
    Mandal, Norway
    SKF 6202 C3 VG104
    Husky updated their bearings to VG104 in some 90's, you probleby won't find the VG104 bearing on SKF's homepage but its available through SKF, I've bought it from them
    PA Dan, smokey7, Mattyo and 2 others like this.
  7. Adamski
    May 3, 2017
    771
    1,651
    208
    Essex, UK
    Thanks, couldn’t remember if they were 6202 or 6203 :)
  8. Finnrpm
    Finnrpm Well-Known OPE Member
    Dec 14, 2016
    45
    99
    63
    Finland
    Is that bearing with plastic cage? Those cost around 40 euros, and takes a week to ship....... I just put SKF 6202-C3 in a 340/hyway cyl. & meteor piston along with new seals. Bearings were branded " explorer " whatever that means!!! They are mentioned to be ok to 28 000 rpm....... And cost for set of two were less than 8 euros.
    RV
    Tor R, Dub11 and RI Chevy like this.
  9. Mattyo
    Mattyo Youtube speciawist
    Jan 8, 2016
    3,354
    7,461
    295
    Farmington, CT
  10. Tor R
    Jan 8, 2016
    2,921
    13,100
    406
    Mandal, Norway
    6202 C3 VG104 isnt plastic cage, if I remember correct VG104 stand for improved cage materiale.
    Nowadays its SKF Explorer 6203 C3 VG104.
    Finnrpm and RI Chevy like this.
  11. Adamski
    May 3, 2017
    771
    1,651
    208
    Essex, UK
    I’ve ordered some skf c3’s before seeing these latest posts. I have some AM seals. Never had a problem with any tbh. Thanks again guys.
    smokey7, Tor R and RI Chevy like this.
  12. Finnrpm
    Dec 14, 2016
    45
    99
    63
    Finland
    had bearings with plastic or improved cage material. It had a airleak ( plastic intake clamp ), belonged to a friend who asked how much for repairs, said 25 euros if only the clamp, 50 euros if bearings & seals also. He said too much, you can keep the saw for free.......
    Of course could not leave the saw like that ( Thanks to Mattyo's posts & videos!! ), ordered p&c kit ( hyway / meteor ), new bearings & seals. Seals which i bought look same as the originals that came out from the saw when took it apart. Previous owner said he bought the saw new, so that is the reason why i'm asking about the cage material. After first impressions been looking local craigslist for used 340, 345 and 350 saws....
    RV
    Tor R, Adamski, Dub11 and 1 other person like this.
  13. Adamski
    May 3, 2017
    771
    1,651
    208
    Essex, UK
    Would someone in the know be happy to give me a quote for either a good clean NE used 346 top end kit or a NE new 346 top end kit posted to the UK? I cannot for love or money find any in the UK!
    sunfish and RI Chevy like this.
  14. psuiewalsh
    psuiewalsh Basement Bodging
    Dec 23, 2015
    1,548
    3,501
    293
    Nottingham,pa
    @Spike60
    RI Chevy and Adamski like this.
  15. Adamski
    May 3, 2017
    771
    1,651
    208
    Essex, UK
    So question tonight is... do the port numbers change much between the 346xp oe and ne jugs being the same crank stroke etc and all??? just a question
  16. sunfish
    sunfish Pinnacle OPE Member
    878
    3,432
    235
    Success Mo
    I've never checked, but the OE feels more snotty and quicker to rev. Must be a little different.
    Tor R, Adamski and RI Chevy like this.
  17. Adamski
    May 3, 2017
    771
    1,651
    208
    Essex, UK
    So I looked and looked and ran out of steam for a sub £200 346ne oem cylinder kit over here but came up with blanks.. so I bought a Hyway kit. It was meant to be a 44.3mm kit but measured 45mm. Has very nice plating and port finishes. Nicely beveled no scraggly castings. It’s a quad port... and.... wait for it... the numbers are the same as a toast 42mm oem top end I have.... then the transfer tunnels are big. Bigger than the 42mm OE anyway. Anyway built it up as is and slapped it through some 8 inch hornbeam. It runs like a slapped panda. It’s as if they have copied a 42 port numbers, opened them out and used the 44.3mm casting and bored it out. Overall I’m pretty happy and it’s the best out of the box AM kit I’ve used. And it came with a caber ring too
    The 340/46xp can now see some run time this spring and then I will think about improving those numbers.
    sunfish, Finnrpm, Dub11 and 5 others like this.
  18. Finnrpm
    Dec 14, 2016
    45
    99
    63
    Finland
    I'll keep using these.....
    RV
    Tor R, Adamski and Onan18 like this.
  19. Adamski
    May 3, 2017
    771
    1,651
    208
    Essex, UK
    does anyone else have problems with a rattly clutch when the saw is not running? It works perfectly and everything looks spot on but the springs (oem original) rattle about? any reason to change them out?
  20. Finnrpm
    Dec 14, 2016
    45
    99
    63
    Finland
    Yes, same noise over here!! Those springs could be little stiffer if you ask my opinion.
    RV
    Adamski likes this.
Loading...
Share This Page
Loading...
Best Buy Co, Inc. GeekBuying.com
TireBuyer.com
