Adamski
Plebus Splederns
- 12:18 AM
- May 3, 2017
- Essex, UK
Lean those screws out some, 3/4 to 7/8 turn out from bottom will be closer
Yes, too rich can make the same bog off idle as too lean. This bout drove me crazy a couple years ago. Also 11k rpm wot is way too low. Lean the H some and get it up close to 14k
Still no luck, set them both at 3/4, 7/8th's, 1 and 1.
Still no luck. Managed to get it to run but there is a big old bog before it picks up and no matter how lean or rich I make it on the Low AND High jets it is still there...
Got another carb off a 346ne that I might try, will just need to block the primer bulb barb.
