- 4:02 PM
- Jan 8, 2016
- Farmington, CT
Ok, lets do... $435 PHO shipped to lower 48 or $485 w/ 20" powermatch bar and chain. chain is pretty sharp. but used.
This saw literally was pieced together from almost nothing. I desperately tried to make it as complete as possible. Still missing one screw for the air filter housing and 2 air filter clips.
So, oem cases, new nachis, hyway seal kit. Meteor piston. Base gasket delete, squish is around .017". 160 psi or so comp. I literally have one cut on the thing. Ported Oem cylinder head, base gasket delete with 1184, kitted tilly carb. I mig welded a red97 deflector on the muffler. Outer and inner dogs, new chain catcher. New o-ring for the oiler, new intake partition. New fuel line and filter. New spark plug. oem coil and flywheel and oiler. clutch works fine but may need new springs.
AM top cover, starter and clutch cover. The brake flag was too tight on my hands so I swapped it with a 394 flag. much better. The clutch cover is pretty nice and works well. The starter you may want to change out but works fine. AV mounts are ok, though I replaced one of the larger ones.
Theres a lot of time into this saw, and it'll be in an upcoming video series. Pix to follow....
So, no warantee. I want this saw gone. I don't need it, but the price is fair so it is fixed. This is a full rebuild ...and these usually take me a VERY long time to do....lots of time here. paypal FF, ship to lower 48 only. you buy it, its yours. I have about 1/2 tank on it and a total of 1 cut.
