Whitty21
- 7:10 AM
- Apr 2, 2016
- Ontario, Canada
For what it's worth, I removed the base gasket on my 285cd and the squish was perfect, about 0.025" IIRC.Anyone able to confirm that this is a thick ring piston by looking at it? I will have to tear it down, but it would be nice to order the rings first.
Also, is there generally enough room to run these without base gaskets?
Those appear to be thick rings. If the saw is running well why do you want to tear it down?
Glad u got it! I'm with redfin on maybe keeping it together. Looks more like scuffing from carbon from conventional pile. I think maybe the good fuel and full synthetic, and it would cure that. I could be wrong, but run into the same problem.I would feel slightly more at ease with the transfer from the slight rubbing on the exhaust side cleaned up and some new rings
That's a good choice on the re-ring job. That saying: "if it ain't broke don't fix it" always applies, but I strongly believe in a full dismantle for internal cleaning/inspection when buying an old well used saw like that.
I agreeNice!! Will be a good freshen up!
