Mr. Bendt Hvid Kristensen
New OPE Member
I have purchased a Mityvac 8500 vacuum / pressure pump, and is studying a Husqvarna 137 e-series hobby saw for leaks, the saw will not start and I found out that the rubber ring between the carburetor adapter and the cylinder was cracked in the longitudinal direction. I replaced the rubber ring with a new original spare part.
Then the saw could start but run irregularly, it runs at an irregular idle speed and after sowing a little, it stops.
I have replaced the fuel hose. I have pressure-tested the needle valve in the carburetor, and it holds pressure.
I wanted to test the engine housing, to check if the oil seal rings were leaky. Together with the above-mentioned Mityvac, 3 wedge-shaped rubber plates followed to seal between the muffler and the carburettor. I can put them between the muffler and the carburetor, but since the carburetor is mounted on an adapter plate, the pressure is released through the above-mentioned rubber tubes and impulse tube, and I can not build pressure at all.
I pump the air into the engine housing via a spark plug adapter, and the piston is in the bottom position.
Someone who has experience with this saw, what is the reason it runs irregularly? ........ the saw has only been used for a few hours and has always been running Aspen 2T, but the saw has stood still, Few years.
I'm from Denmark, so have indulgence with my bad English.
