oaky
- 7:01 AM
- Nov 18, 2018
- massachusetts
talked a little about this saw in a previous thread, there was some interest so i cleaned it up and made its own thread..
all original oem parts, good crankshaft, good bearings, no north south play, case is in decent shape(except piece broke off near clutch,) fuel tank is solid no leaks filters in there working trigger and safety latch, flywheel has no marks, clutch is good.
rest of the separated parts are in fine shape except the clutch cover/brake assembly(exhaust melted it and ruined it, disassembled the chain brake assy for separate use.) you can throw the clutch cover on there as is.
all the smalls pictured are the piston assy parts, head bolts, muffler bolts, nuts and gasket, brake assembly parts, throttle trigger, and corn kernals (from the dang mice..)
cylinder has piston transfer can be removed, also two dings near the exhaust port.
missing/needs -
p/c, air filter screen, ground wire?, a working clutch cover/chain brake assy, tank handle tabs, bar nuts, lines and maybe screws?
figured this might be a good saw for someone who already has parts lying around. if i dont get a decent price ill probably keep it. pm with offers.
missing/needs -
