- 8:49 AM
- May 30, 2016
- Ct
Ok guys, I have the opportunity to test a 462 for the next couple weeks and no I wasn’t paid by stihl to do this before anyone asks. This is my honest opinions. This thread will detail my experiences and stuff. Kind of like the 7900 thread I started.
I will probably first start using it at work this coming week (I’m a full time logger). I haven’t cut with the saw yet... but I did take the time to inspect it closely. My first impressions... picking up the saw, the ergonomics are the best I’ve felt on any stihl ive ran before. It felt comfortable and sleek. It felt similar to a oe365/372 lowtop saw is the closest thing I can think of. The saw has a 25” es bar on it and with a full tank of fuel and gas the balance is about perfect to me. Slightly nose heavy. I imagine a sugi or tsumura 28” would be balanced about the same as the 25”stihl es.
The av is good, not floppy at all yet smooth. I like how the front and rear spring is mounted vertical. A metal wire inside the cylinder spring, lower front limiter pin and right side limiter pin appear to be the av limiters. They looked plenty sufficient for a saw of this class.
I did notice the filter has a radial seal like a 661 (usually I don’t like the 661 setup), but this appears to be a better setup, no backplate for dust to sit behind and fall into the intake every time you take the filter off. I did put a little grease on the radial seal, seems to fit snug. The filter is washable and twist locks on. I like the top cover twist pins, quick and easy. Locks on very tight.
I noticed the use of a wire instead of a cable for the throttle, liked that. Throttle cables wear out faster. It appears to be a good idea to grease where the wire contacts the plastic slide for actuating the throttle. There was grease from the factory there. I like how they used a “372xt style” strato. Really simplifies the airbox setup. The throttle response felt fast and smooth. No hesitation. The reset procedure for the mtronic is easy and pretty cool as well.
I punched in the oiler pin for max adjustment range (like a 661 pump) and this thing appears to oil way better than any previous 1128 stihl I’ve used. Absolutely slings oil off the bar. I look forward to giving another report after I cut with it some... but first impressions are good.
By first looks, the only things I would do to this saw if it was mine is maybe install the wider west coast cover for more chip clearance (the standard cover looked slim, probably to save weight) and dual spikes with a roller catcher.
