Clemsonfor
- 5:34 AM
- Jul 21, 2016
- Greenwood SC
Ok guys I don't post that much here. This place is so busy I can't keep up with your pace. Ha.
I am pretty good with two stroke and saws, but this blower has me scratching my head.
It started showing classic carb problems. Like having to run on half choke to get WOT. Then it got to where it wouldn't do much that fire off and die. No big deal. Ordered it's carb kit from china. Put it in and it started right up and runs. But even once warn ot would run then fall on its face. Yoy can push choke back to half or full and it will got wot on half then you can move it back off choke and it runs 2 or 3 seconds perfect then will bog out like it's starving for fuel. I thought it was still carb, I have had carbs that just wouldn't work even rebuilt. So I buy a China carb off ebay for it. I installed it and it acts the exact same way!? I swapped the kit out of the OE one to the replacement , no change.
I have even pulled of the fuel filter thinking it was plugged. It runs the exact same. I have swapped all the fuel lines so it shouldn't be suckling air out of them. I don't think air leak cause it's so repeatable and not random. Rev it with choke switch it off and it like runs out of fuel, choke again and you can get it back up to speed and then it will bog out again.
I really am scratching my head here.
