Thanks guys. I got past this, going to use an open port, NOS OEM 46mm top end on this one.
Waiting for mail man. I have beginner thoughts.
Ring gap looks like .007+
Do circlip positions matter? Open side up? And or?
If, I go without cyl gasket, should I stuff a wire into impulse hole during install to be sure Dirko grey +575f degrees sealer does not plug it?
Vac pres test seems good. Bearings feel good, seals are new,
motor is real clean.
If I can get the original carb cleaned and kitted I'm using it rather than the AM.
Any comments good, bad, or ugly appreciated.
I could never have got this far in learning without you guys,
and no one around here wants to work on these old saws, thanks.
These little buggers are not at all like small blocks.
