- 1:14 AM
- Jan 21, 2016
- Missouri
The carb on my 372XPW has no fuel flowing to the low side needle. I cleaned the carb and installed a new kit but it will not idle and it I can get it to Accel it sounds super lean. If I choke it, start it and keep it above half throttle it will run and four stroke with the high needle out about 1.5 turns. Even with the low needle out 5 turns it still won't idle or Accel.
I pressure and vacuum checked the crankcase and it's tight.
Is there a trick to this carb that I am over-looking something?
