jackjcc
- 6:59 PM
- Apr 22, 2016
- Minnesota
Fixed the saw a year ago for a tree service and they’ve spent the last year running it daily. That an incomprehensible amount of use to me. Well the last time it came in the spark plug electrode broke off and after bouncing around the combustion chamber a little ended up in the crank wedged between the counterweight and the case. No damage to the cylinder, beside a few small dings in the top.
It came back locked up and looking into the plug hole showed chunks of aluminum on top of the piston, sad face followed. The case is littered with debris, but the guy running it said it was locked up when he tried to restart it, fairly certain it happened when operating. Lots of little fine pieces everywhere.
You can also see the wear on the piston skirt, seems like it ran a little lean, but on the other hand there wasn’t much for oil in it and what was there is red in color. Can anybody name the brand that has red oil?
Anyways the debris came from the cylinder base, can’t think of anything that would have caused this other than bad luck. If somebody knows please speak up.
Not sure where to go from here, the bearings turn over smooth still and if I wash out the case with mix I feel like I will push the small particles into the bearings. What do you guys think I should do with it?
