I got a Husky 285CD that I bought for 50 bucks. I did the usual clean up on it. Checked it for spark and it had some. hit it with starting fluid and it popped. So I tased it up and now I get nothing even with starting fluid. Checked spark it got some . Starting fluid getting to plug and it is new. I have sent 2 days trying to get the flywheel off NO luck. Have used the brass hammer on it nothing. Rigged up a puller tapped on it while tightening it up puller brakes loose. It is not a very good set up but it should work. I am now thinking it has jumped timing. Can't tell by looking at the woodruff space. So what's next. Is there a TRICK to getting the flywheel off a 285CD. I got a steering wheel pull coming.. I will try that. If that does not work I don't know what to do. Thanks for any help.
