Husky 272xp CFB style
Canadian farm boy
“Normal” people scare me.
4:42 AM
Ontario, Canada
I got to work on the saw and my first order of business was to check the stock squish numbers and port timing.
I checked the stock squish with a .020 base gasket and measured a tiny .013". Without a base gasket it was a head slapper.
Stock timing numbers with a base gasket were
104/121/71. IMG_5202.JPGIMG_5205.JPGIMG_5208.JPG
Canadian farm boy
4:42 AM
Ontario, Canada
I contacted a couple members here and did a little brain storming @rattler @Stump Shot @drf256
Thanks for the advise and tips guys. Now armed with a bit of knowledge of this saw and some insight from these great guys I concocted a plan and proceeded to execute it.
Canadian farm boy
4:42 AM
Ontario, Canada
My first order of business was to cut the cylinder base and squish band.
With the saw having such a tight squish to start with I cut .015 from the cylinder base and extension and .020 from the squish band. This gave me squish clearance of .018 with a .020 paper base gasketIMG_5210.JPGIMG_5211.JPGIMG_5229.JPGIMG_5225.JPG
Canadian farm boy
4:42 AM
Ontario, Canada
Having the cylinder all machines and my squish clearance set I got to work at making it breath a bit better. Decided I'd go with ported timing numbers of 102/121/78. The upper transfers were nearly perfect. All I needed to do with them was clean them up a bit.IMG_5241.JPG IMG_5243.JPGIMG_5242.JPG
Canadian farm boy
4:42 AM
Ontario, Canada
@CJ Brown supplied me with a used oem 272 piston and a new meteor piston. I took various measurements of both pistons and compared. I didn't get pictures of my measurements but the 2 pistons were within .001" in every dimension that I measured. I even measured the thickness of the circlips. They were identical. I used the oem piston for all mock ups as I didn't want to risk marking up the brand new meteor.
This is where I had a little fun. I weighed both piston assemblies. The piston, ring, wrist pin and circlips.
First picture is the oem, second picture is the meteor.IMG_5277.JPG IMG_5278.JPG
Canadian farm boy
4:42 AM
Ontario, Canada
I noticed the meteor piston has some casting flash and a few rough edges around the piston windows. Knowing that the meteor piston assembly weighed a touch more then the oem I proceeded to smooth things out. I did not do this with the intention of lightening the piston but with the intention of making the surfaces smoother. When I was finished I reweighed the piston assembly. I was pleasently surprised. The meteor piston assembly now weighs the same as the oem. If you look closely at the picture you can see a bit of the clean up work I did.IMG_5282.JPG
