- 12:21 PM
- Dec 30, 2015
- Brewster, NY
Yea, you did well, that chain had way too much beak when you got it.
@Deets066I read in TN gtg thread about spending 25-30 hrs on a chain. Thought it would be better to ask here. What can be done to spend that much time on one?
In the extreme you can build the up entire chain from scratch/individual parts.
The side plates get thinned, dog boned and radiused, rivets shaved back, cutters reshaped/tunneled out and chrome removed, stoning each cutting edge after filing, depth gauges thinned/reshaped.
Who knows what other endless little details...
I've heard of 40-50 hrs on one.
You make it frail and weak, then run it at speeds and hp insanely over what the original stronger version was designed for.
And brace yourself...
Edit; Got me curious. My quick 'n dirty calculations put a cleanly thrown hotsaw chain at similar muzzle energy to 223 rem.
I don't stand in front of those things even at a good distance...
That should cut at a decent speed!!
I am embarrassed to post my chain lately ,the table on my grinder is getting loose making the cutters a little off from one another ,need a the upgraded one soon scarr sells .Looks real good Bryan. [emoji106]
so what is the down side (once you learn to do it)?
Square filed, or ground chain is smooth, durable and faster than round. It is not very common and takes some commitment on your part if you want to switch over. I say it is worth the effort even for firewood.Ok, smack me, kick my azz and call me dumb. For an average firewood cutter like myself, would there be an advantage to square filing or is this more for high performance saws? Thanks.
