How to square file
Duane(Pa)
It's the chain...
12:45 PM
Centre County
John is a guru of square filing without a doubt. Somewhere along the line he says to “be the boss of the file and don’t let it skate around. Make it go where YOU want it to be...”
Of course this requires that the tooth is held very securely.
12:45 PM
My advice:
Look at that Madsens site
For hardwood/general cutting: 45* back, 45* down and 45* angle. Also remember square is from the outside in, not the inside out. Your file will contact the strap on the far side, which will help to guide your angles. Always make sure the corner of the file is in the corner of the tooth, and that you stroke straight.
old guy
Love me some Husqvarna
11:45 AM
Becker Minnesota
It's certainly not when first starting. I started learning and would've kept at it, but... After people talked about how much faster square milled. Then thinking about square filing 150+ drive link chains, I just went ahead and bought a Simington. I gave up on hand filing after that.
Amen to that, my square files are now raker files.
kfd518
11:45 AM
Central Texas
Need to bring that side plate angle back square to or a couple degrees under the working corner. Top plate angle looks quite steep as well
File angle 45* back,45* down 45* tilted from wide side flat towards vertical is a decent starting point.
Not by any means perfect but someone will be along in a bit with a better pic and explanation.DE411E52-09B8-4DD0-A19F-E35D1D7A90CA.png
kfd518
11:45 AM
Central Texas
Forgive the old funky file it was already in the truck. I use a shallow top plate angle and just enough side plate angle to get a decent bore cut and self feeding.
Chain is loose in these pictures but just trying to give an idea of file angles.
5C972673-4A2B-45A1-B269-208BA0CA554F.jpeg 2F9E4758-E43F-4592-8387-DEE2AA7A1173.jpeg 5B9C1CB3-0748-4C98-8030-2A23E69DFB71.jpeg
mettee
9:45 AM
Arizona
I'm a little happier with this tooth. View attachment 202380
Angles are off, but thats why you are here. To learn.
Set up your saw with the bar horizontal. Tighten the chain extra, just so that you can still move it on the bar. That will keep the cutter in place while you file. If the cutter moves while you file you are shooting yourself in the foot.
Now. You have seen 45*45*45 and that is exactly what you do. Your file will file the back strap if you are at the right angle. 45 back, 45 down, and 45 so the large flat on the file is flat but follows the 45 down angle. I said horizontal, that is partially correct but not really.
