- 8:48 AM
- Dec 31, 2015
- East Jordan, MI
Lol.Sounds like Charlie Brown's teacher...
Or a McDonald's drive thru
Looks good to meThis is the second cutter I've ever squared and I'm looking for advice. What do I need to work on? What stands out?
Looks good to me
I'm tryin'!!Now get all the rest to look the same.
Its easier once its square, vs converting from roundThanks...I won't show you the first one I did..ha!
I notice it's easy to beak the point. But I think I'm getting the hang of it?
They are touchy, gotta file inside out. Hard to get the same angle as filling from outside in.I wish that a manufacturer made some diamond chisle bit files.
Would be awesome to finish with
If..... you had one. You may see the issueNot sure what you mean. If I had a diamond file for square file I'd just regular file then follow up with the diamond file to finish. Don't see an issue with filing the same direction with a diamond
file... maybe I'm missing something.
You think the chrome will clog or the diamond will chatter on the cutter? Curious...If..... you had one. You may see the issue
