How to square file
ChipsFlyin
OPE Platinum Member
11:51 PM
Pittsburgh
Cool!
NOW...... If I could only measure the gullets and stuff. Lol
I just go by feel. How the chain works. Super scientific!
I do the same. Sometimes I have a chain that is performing better than usual, now I can take a look and really figure out the way it is set.
Moparmyway
Its just a saw
11:51 PM
In a meeting
moparnut88
11:51 PM
US
Yes it is, I’m looking for a used grinder at the moment but certainly nothing around HERE. Used.
Keep your eyes peeled. I looked for a couple months. Ended up finding a 450a on Ebay shipped for $550. There are still deals to be had just takes patience.
kfd518
10:51 PM
Central Texas
In the mean time I’ll just keep trying to perfect my filing. Been using Stihl hex files for a while trying to do .325 they are just to fat to fit. That and I think I need to make/buy something like homelite410’s chain jig
moparnut88
11:51 PM
US
Yes his jig is the best! I ended up making something similar to get me by. I was using the save edge files.
Ryan Browne
10:51 PM
Wisconsin
Those chain vises are worth every penny.
ChipsFlyin
OPE Platinum Member
11:51 PM
Pittsburgh
I forget who, but someone (I believe it was a member here) told me a while ago to set rakers by angle. I used a small magnetic digital angle finder on a piece of flat stock steel ......... never looked back since.
There's a phone app called Angle Meter that is very accurate depending on the phone. It only measures full degrees but still really cool. I was playing with it yesterday. The saw/ bar does not have to be level. Set the phone across 2 cutters. Get that degree usually 1,2,3 off if level. Drop the phone on the raker and see where it is. I found that if the rakerd is flat that had to drop the phone of the chain a very small amount and re file the cutter so the degree measurement is the whole way across the raker.
Skeans1
8:51 PM
Oregon
Am I the only guy that grinds them flat? Normally takes one tree down to smooth out for the rest of the day.
ChipsFlyin
OPE Platinum Member
11:51 PM
Pittsburgh
No- most if use get them where they need to be and cut wood... I normally only really measure 1 or 2 cutters and guesstomate the others. The super precise stuff with each cutter and raker is only if I want to do a play/ fun chain.
Willard
10:51 PM
Manitoba
When you think about it, when the cutter is cocked back in the cutting position the square leading corner of the depth gauge is now higher then your "flat" setting.
I always take that leading corner off with a half stroke of the flat at a 45°.
After a hour or so of cutting that leading corner will be polished smooth in a even curve.
concretegrazer
10:51 PM
Mo
Chain vices are nice. But if you can't file on the bar in the shop you'll never be able to do it in the field.
