- 6:24 AM
- Jan 17, 2016
- cape cod ma.
I'm a little late to this party, Hats off to ya Randy. Excellent work
and documentary.
and documentary.
Price go up after you hire an engineer to finger it out?Looks like I'm having to redesign the needle here. Too sharp, and seems to be obstructing the passage too much.
I'll post some pics of the new needle one day next week.
When you drill a hole to provide fuel to the low side so that it doesn't pull fuel from the nozzle well, do you block the low side passage in the nozzle well?
That brass jet sitting next to the welch plug, is that an auxiliary jet to the low speed circuit? Sure looks like it, if it is then bumping up the low speed flow is really easy, all you have to do is drill it out (finding the right size is the hard part).
I like this mod a lot, I would like to carry out mod on a spare WG8 that I have.
The only part that I would struggle with would be creating the seal on the new needle.
I assume I would need a lathe to cut a recess for the O ring to create the seal around the new H needle ?
Yup. It's not that critical on a low speed circuit to need an oring in this application. The other work you do in there really matters.I just use a drill bit.....and a steady hand.
Keep it simple.
Would you consider selling one of your custom needles to me in the UK?I just use a drill bit.....and a steady hand.
Keep it simple.
If you are happy to sell, how much would the needle cost, please include shipping.
If I may request the cheapest form of shipping, even if its sent via land and takes 3 months thats fine.
I assume its not possible to use the a Low needle for the high ?
My address is as follows:Send me an address.
Did you receive my address ?My address is as follows:
private message sent with all my details
Put the drill in the right place then get it to run true.
All that done on a little cube with a tiny bit.
Good lighting , an optiviser, readers and clear head. How often does all that end up all together at once?
Get it right then you want to do another one.
Yep, it will get expensive.
Need any secondary metering rods for Q jets? Gawd i'm old!
Hi,
Any news on the quote for the needle and postage to the UK ?
Will a standard needle work and if so, how would I need to modify it ?
thanks
Gavin
They always doI've got one ready to send....but my fiber is out. I can't get on the Internet to print a label. For the last couple of days, just been able to use my phone. They assure me that they are working on the problem.
