JimBear
6:50 AM
IA
I’ll throw this out here on the “local” thread before I post them elsewhere. I’m not sure if I needed more coffee, less coffee or just needed to pull my head out of my a** before I ordered these, obviously the latter but there is 20% restock fee & shipping to return them & they don’t stock 66DL. I paid $13 each for them & I will pay for the shipping or deliver/meet you somewhere if you are close enough ( Des Moines, Omaha, KC, we have kids in all three). 3/8” x .050” x 68DL x 18” full chisel. I have 12 of them. :rolleyes: PM me if you have any interest.
cobey
6:50 AM
Pittsburg, kansas
I
I Might have a little bit of that stuff left,
Where are you? Might be able to fix some of them
Hedgerow
6:50 AM
I've used them last year and my neighbor used them this year. I think I need to set them out earlier in the year or the old creek across the street from me is just to much for them.
Congrats!!!!!
What did that kid with the Deere get?
3rd, right behind the really cool flatbed trailer a kid from Sarcoxie built.
It had an 8 foot hydraulic dove tail ramp and tandem duals.
JimBear
6:50 AM
IA
With duals & weights I would guess around 12,000#, seems like those old FORD’s were pretty heavy, iirc. With no cab it would lighten it up but if there is fluid in the tires that could add quite a bit of weight.
JimBear
6:50 AM
IA
My initial thought was 14k but I backed it down
I guess I should of stayed with my initial thought
Ford 9600
1972 - 1976
Row-Crop tractor
Previous model: Ford 9000
Next model: Ford 9700
Series back: Ford 8600
Production:
Manufacturer: Ford
Original price (USD): $17,300 (1976)
Ford 9600 Engine:
Ford 6.6L 6-cyl diesel
full engine details ...
Capacity:
Fuel: 43 gal [162.8 L]
Hydraulic system: 16 gal [60.6 L]
17.25 gal [65.3 L] (Dual Power)
Steering: 3 qts [2.8 L]
3-Point Hitch:
Rear Type: III/II
Rear lift: 18,000 lbs [8164 kg]
Power Take-off (PTO):
Rear RPM: 540/1000
Dimensions & Tires:
Wheelbase: 91.5 inches [232 cm]
108 inches [274 cm] (row-crop)
Weight: 11860 to 18000 pounds
Front tire: 7.50-18
Rear tire: 23.1-34
full dimensions and tires ...
9600 Serial Numbers:
1972: C327200
1973: C367300
1974: C405200
1975: C450700
1976: C490300
how to read serial numbers...
Ford 9600 Power:
Drawbar (tested): 111.40 hp [83.1 kW]
PTO (tested): 135.46 hp [101.0 kW]
power test details ...
Mechanical:
Chassis: 4x2 2WD
Steering: hydrostatic power
Brakes: differential hydraulic wet disc
Cab: Open operator station. Cab optional.
Hydraulics:
Capacity: 16 gal [60.6 L]
Pressure: 2500 psi [172.4 bar]
Pump flow: 16 gpm [60.6 lpm]
Steering flow: 4.2 gpm [15.9 lpm]
Steering cap.: 3 qts [2.8 L]
Steering press.: 1500 psi [103.4 bar]
Electrical:
Ground: negative
Charging system: alternator
Charging amps: 55
Battery:
Volts: 12
Amp-hours: 128
Page information:
Last update: November 11, 2016
Copyright: Copyright 2016 TractorData LLC
Contact: Peter@TractorData.com
Hedgerow
6:50 AM
All fluid out of tires, new tubes installed.
All wheel weights off also. 2 of em were 500 pounders.
What's it weigh?
Without duals or fluid, 11,000 pounds.
Not sure what the duals weigh.. "maybe" 500 each or so.
JimBear
6:50 AM
IA
For @Dub11 just in case your Burban
chits the bed, or at least I thought you referenced having a Burban.
1978 Malibu station wagon
$11,500
Details for 1978 Malibu station wagon
Jul 10, 2019
1978 Malibu station wagon. 355 SBC angle plug heads, holley 670cfm street avenger, headers, Muncie M21 4 speed, hurst shifter, centerforce clutch with under 500 miles on it. Autometer gauges, after market stereo. All new suspension BMR springs, UMI performance sway bars front & rear. Bilstein shocks. New stiffer aftermarket rear control arms. New bigger front spindles, new brakes front & rear. Comes with bucket front seats but also have bench seat that will go with it. This car is in excellent condition & runs very very well. $11,500. 712-621-4666
  • Listing Type
    For Sale
  • Model
    Malibu
  • Price
    $11,500
  • Year
    1978
6:50 AM
$11,500
Jul 10, 2019
  • Listing Type
    For Sale
  • Model
    Malibu
  • Price
    $11,500
  • Year
    1978
SWEET!!!! Can it hold 6?
67L36Driver
6:50 AM
Then the inevitable question...
Thomas?? What are you doing in a store that sells those???
[emoji848]
