Well Carl I do have a few 346s. You might be able to talk me out of one
The biggest hurdle is spark. The coil insulation has a tendency to crumble with age. If you have spark, you'll soon have a runner.If you have never met moparnut88 I'll tell you what; great young man could not have been more instructive. Had me operate Dolmar, Husky and some other. That's the trouble I have had for 46 years; he provided tens of thousands of dollars of info. Only if I wood remember it. Dain bramage , most troubling short term memory
That Mall he troubled himself to get; it's got full, or near, teeth . Crank rotates with compression. Haven't sprayed any mix into the carb
Depending on the model, there's a military surplus coil that works well. It's inexpensive and a hot firing booger too.Bendix Scintilla magneto?
There is a ‘work around’ for them.
Use a Wico coil found on Homie XL-101 types and Remington SL-9 types.
And where might these be obtained?Depending on the model, there's a military surplus coil that works well. It's inexpensive and a hot firing booger too.
