2019 Silverado 2WD and 4WD and maybe others later.What models will it be available in?
Might be a good pairing with a light, short bed, regular cab pickup.2019 Silverado 2WD and 4WD and maybe others later.
Inline 4. The 2019 Silverado is reported to be using magnesium, carbon fiber, and also ultra high strength steel in the bed.Might be a good pairing with a light, short bed, regular cab pickup.
Inline 4?
Local certified mechanic/tire guy/farmer says its easier to lift the body off of the frame than pull the engine on some trucks. For spark plugs I think. I seen the body up and had to ask why is the body off the frame.
Yeah, THATS why I don't have one of those cars!It could be worse. I saw an oil and air filter change on a Bugatti Chiron cost $21k. You have to take the hydraulically controlled carbon wing and upper body off and drain the 18 plugs for the oiling system. Two paper air filters, a paper cartridge oil filter and 16 quarts of 50wt oil... so how much of that $21k is labor?
New stuff is a PIA !Local certified mechanic/tire guy/farmer says its easier to lift the body off of the frame than pull the engine on some trucks. For spark plugs I think. I seen the body up and had to ask why is the body off the frame.
That's more than I like to pay for good used vehicles.It could be worse. I saw an oil and air filter change on a Bugatti Chiron cost $21k. You have to take the hydraulically controlled carbon wing and upper body off and drain the 18 plugs for the oiling system. Two paper air filters, a paper cartridge oil filter and 16 quarts of 50wt oil... so how much of that $21k is labor?
I've always had good luck with a small pair of knipex channel lock pliers.Fixed!
[emoji322][emoji322][emoji322][emoji322]
Tools needed included a 5/8” dia x 24” rocker foot bar and a 1 x 2 x 24”.
The linkage ‘snaps’ together with a lot of encouragement.
Yep they are invaluable in my opinion.Used those also, my big one and the medium.
Oh yeah...sure. Uh-huh. That's it...That the only reason?[emoji15]
Sent from Hoskey Hills
