honda gx 390
ppea
OPE Member
7:22 PM
romania
I have a brand new gx 390 and it was surging at high speed,i clean 3 times carburetor, make hole larger in the pilot jet and now run perfect but start only with choke even when it's hot.ideas?
Bilge Rat
12:22 PM
savannah georgia
Pull off the bowl then remove the main jet .
There is a tube, emulsion tube i think it's called it will fall out.
Clean out the small holes in the sides of this tube with a small micro drill bit, #77 i think.
I use the back end of the bit .
This has fixed 3 Hondas for the surging issue in the last 3 months.
Cleaning the carb without pulling the tube does not fix the surging in my limited experience.
Lightning Performance
12:22 PM
East of Philly
Ditto on Briggs twin electronic carb. Did it once.....needs done again. Two years little use. Plastic is worse than brass. Tubes like this clog in Echo mini blowers twister carb.
Lcfd1124
12:22 PM
Honea Path
You can go to home depot and get a mig welder tip cleaner. These are absolutely wonderful for cleaning emulsion tubes and jets. The tool has many different size wires so you are sure to have the right one.
Wonkydonkey
Plastic member
5:22 PM
Sussex, UK.
But.... does the op... have a Home Depot where he lives... in Romania..
But really..just. find anything that works for you.. I’ve used new and old toothbrushes for many things. Those bristles are great.:D
