T.Roller
- 4:15 AM
- May 11, 2016
- Southeast, TN
I'm in
Jon you will definitely want to use plenty of cutting oil with that bit. I have never used one on hardened steel but they work great on mild steel and even work decent on stainless steel.A big THANKS to Jason @USMC615 for "hookin' a brotha up" with some very useful attachments to make my efforts much more feasible.
This for cutting the holes that will be the ends of the cutout ovals.
And this 30 pc assortment of 1/8 shank carbide bits for finish work.
I am still trying to come up with a few options for filler.
I want to keep air bubbles to a minimum for obvious reasons, but am thinking a two part epoxy with a longer open time/ slower cure may be the way to go.
Thoughts?
Got this 32" in a stack of used bars, from the Doughnut drop off. So to answer your question, yes.
Aircraft use a honeycomb structure with thin skins for lightweight panels.I am still trying to come up with a few options for filler. . . Thoughts?
Expanded PVC is very light, with smooth sides, and very easy to work. Sold as signboard, ceiling panels, etc. Trick would be to get the right thickness, and to find the right glue / method of attaching. Cut pieces to fit your holes with a router.
Philbert
I've used that stuff under my powder coating.http://www.eastwood.com/hi-temp-lab-metal-24-oz.html
Anyone have any experience with these type of products?
I don't know... Babbitt is lead or zinc based and not super tough. My pap and I (mostly him) used to pour bearings in projects when I was a kid... I remember it being pretty heavy.cut holes in the bar using a metal hole saw and fill the void with babbit because it is pretty light stuff but strong.
This seems like the way to go.http://www.eastwood.com/hi-temp-lab-metal-24-oz.html
If it was easy, all the slackers would already be doing it! You would probably want some kind of mechanical connection (keyway, slot, groove, recess, etc.) along with glue or heat welding the plastic.I think trying to bond expanded PVC to hardened steel would prove very challenging.
